https://help.tallysolutions.com/docs/te9rel66/Voucher_Entry/Inventory_Vouchers/Transfer_Journal_Voucher.htm
Transfer Journal Voucher
Tally.ERP 9 allows you to transfer materials from one Godown to another. The transfer of materials is done using the Transfer Journal Voucher.
Record Transfer Journal Voucher
Print Stock Transfer Voucher
Stock Journal Printing Setup
1. Go to Gateway of Tally > Inventory vouchers > Alt+F7 for Stock Journal and select the class.
2. Pass the stock transfer entry.
1. Press Alt+P to print the Stock Transfer Journal Voucher.
● While printing Stock Transfer Voucher, set the options Destination Godown on Top of Voucher and Print Godown Address to Yes .
● Enabling the option Destination Godown on Top of Voucher will display the Destination Godown name on the top of the voucher instead of printing as separate rows
● Enabling the option Print Godown Address will display the godown address as mentioned in the Godown Creation/Alteration screen.
