As per Rule if the principal manufacture is sending the excisable goods for Job work the material Movement details has to be maintained in Annexure - IV. In Tally.ERP 9 Annexure - IV can be generated when the Excise for Manufacturer feature is enable in F11: Features.
1. Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Registers > Annexure - IV .
2. Select the Excise Unit for which the Annexure - IV has to be generated, i n the Select Item screen.
The Annexure - IV is displayed as shown:
'Annexure - IV (Job Work Out Reports)' has been shared with
