https://help.tallysolutions.com/docs/te9rel66/Job_Work/JO_Material_Movement_Register.htm
Material Movement Register Report (Job Work Out)
Material Movement Register displays the details of Movement of Material (Raw Materials and Finished Goods) of Job Orders.
Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Register > Material Movement Register .
Column Description of Material Movement Register
● Order Number : This column displays the Job Order number towards which the material movement (Out/In) is captured.
● Delivery Challan Number : This column displays the voucher number of the Material out voucher through which the materials are transferred towards the Job Order.
● Date of Dispatch : Displays the date on which the materials are transferred/dispatched for the Job Order.
● Description of Goods dispatched : Displays the description/Name of the stock items dispatched for the Job Order
● Quantity Dispatched to Job Worker : Displays the Quantity of each goods dispatched.
● Name and Address of Job Worker : This column displays the Name of the Job worker on whom the order is raised.
● Nature of Processing Required : This column displays the Nature of Processing required. Nature of Processing details will be captured form the Party Details of Material out voucher.
● Goods Received from Job Worker : This column displays the goods (Finished Goods/Scrap/By-Products/Co- Products) received from the Job Worker
● Quantity Received form Job Worker : This column displays the Quantity of Finished Goods received.
● Job Worker's Delivery Challan No. and Date : This column displays the Job worker's Delivery Challan Number and Date entered in the Material In Voucher.
● Factory GRN/GRRNo. and Date : This column will display the Voucher Number and date of Material In voucher through which the material receipts are accounted.
● Shortages if any : This column displays the details of Shortages in the process of Manufacture, if any.
● Wastage/Scrap at the end of Job worker : This column displays the quantity of wastage and scrap produced during the manufacture of Finished Goods.
● Duty Paid on Shortages/Scrap/Wastage : This column displays the details of Duty paid on the Shortage/ scrap/Wastage
● Remarks : To enter the remark as the Job Order is closed.
