https://help.tallysolutions.com/docs/te9rel66/Reports/MIS_Reports/Display_Post_Dated_Vouchers.htm
Post Dated Vouchers Register
While entering vouchers, you can mark them as post dated. Tally.ERP 9 will not update the vouchers in ledgers until the specified date is approached. This is useful to enter transactions that take place on a regular basis. For example, if you pay for something by installments, you can set up the payments in advance, and Tally.ERP 9 will only enter them in the ledgers as they fall due.
Post dated voucher
Post dated voucher register
Post dated voucher
Mark vouchers Post Dated by using Ctrl+T or click on Post dated button from the Button Bar. This button toggles with Curren t .
Post Dated Payment Voucher entry is displayed as shown:
(Above entry will not appear in the ledger accounts, till 10th May)
Post-dated Vouchers Register
All Post-dated vouchers are maintained in a Post-dated voucher Register.
● Go to Gateway of Tally > Display > Exception Reports > Post-Dated Vouchers .
The major difference between post dated vouchers and other Unconventional vouchers are:
● Post dated Vouchers affect regular books of accounts on the date of the voucher
● Post-dated vouchers are not available for selection in Scenarios.
