Different businesses have different requirements. While some businesses deal with a single stock item and single type of transaction, whereas some businesses deal with multiple stock items, and different types of transactions and require a more complex statutory functionality.
Based on the demands of the business, you can select the kind of capability that you want.
Click on a link below to understand more about the robust yet flexible method of defining and applying tax rates in excise.
For a business involving one common tariff rate for all business transactions, refer Defining Tariff Rates at the Company Level .
For a business involving multiple tariffs applicable across various stock items, refer:
Defining Tariff Rates at the Group Level
Defining Tariff Rates at the Ledger Level
'Defining Duty Rates (Excise for Manufacturer)' has been shared with
