https://help.tallysolutions.com/docs/te9rel66/Payroll/Multi_Pay_Slip.htm
E-Mailing Multiple Pay Slips (Payroll)
You print or email the Pay Slips for all the Employees with the click of a button.
View multi pay slip
Button options in Multi Pay Slip screen
View Multi Pay Slip
1. Go to Gateway of Tally > Display > Payroll Reports > Statements of Payroll > Pay Slip .
2. Select Multi Pay Slip and press Enter .
3. Select the required Employee Category and Employee Group.
4. Press Enter .
The Multi Pay Slip screen displays the Employee Names , Account No. , Bank Name & Branch , Amount and E-Mail ID for the Employees.
Press Enter on the Employee Names to view the Single Pay Slip for the selected Employee.
● F2: Period : Click on F2: Period or press F2 to change the selected Period.
● F5: Employee-wise : Click on F5: Employee-wise or press F5 to view the report without the details of the Payroll Category and Employee Groups .
● Ctrl+F7: Employee Filter : Click on Ctrl+ F7: Employee Filter or press Ctrl+F7 to view the report for the selected Payroll Category and Employee Groups .
● F12: Configure : Click on F12: Configure or press F12 to change default view for the Multi Pay Slip report.
● Remove zero-valued entries : Set this option to Yes to remove the Employees with Zero pay value from the Multi Pay Slip.
● Include Employee Groups & Categories : Set this option to Yes to include rows related to Category and Groups. Set this to No to list only employee information.
o Show Category/Group Total : Set this option to Yes to display the totals for Category and Group.
● Show Grand Total : Set this option to Yes to display the Grand total at the bottom of the report.
● Show Employee Number : Set this option to Yes to display the employee number along with the Name.
● Show Employee Bank Details: Set this option to Yes to display the Name of Bank and Branch for each Employee.
● Appearance of Name : From the Display Name Style list, select how you want names to appear..
● Appearance of Employee Names: from the Display Employee Name Style list, select an option to specify how employee need to appear. .
● Sorting Method : Select the appropriate sorting method from the list.
Printing Multiple Pay Slips
1. Click on P : Print or press Alt+P from the above report.
2. Set the above options as required and press Enter to print the Pay Slips for all Employees.
For more information on the Print Configuration options, refer to printing Single Pay Slips .
E-Mail Multiple Pay Slips
1. Click on M : E-Mail or press Alt+M from the Multi Pay Slip report.
2. Set the options as required and press Enter to E-Mail the Pay Slips for all Employees.
E-mail individual pay slip to the respective employee
1. Go to Gateway of Tally > Display > Payroll Reports > Statements of Payroll > Payslip .
2. Select the Employee .
3. Press Alt+M and enter the e-mail details.
4. Press Ctrl+A to accept.
