Return Transaction Book for Form ER 8 (Excise for Manufacturer)
https://help.tallysolutions.com/docs/te9rel66/Tax_India/excise-mfg/em-return-tran-er8.htm
The Return Transaction Book displays the list of Saved Returns. Each time the excise forms are modified.
To view the Return Transaction Book
1. Go to Gateway of Tally > Display > Statutory Reports > Excise Reports > Manufacturer.
2. Click Return Transaction Book .
3. Press Enter to go to the return form.
