https://help.tallysolutions.com/docs/te9rel66/Data_Management/DM_Import_Vch.htm
Importing Vouchers
You can import vouchers from one company to another in Tally.ERP 9. This could be due to the following reasons:
Data corruption/loss.
Migrating into a later release.
Importing data from third party.
To import vouchers
1. Go to Gateway of Tally > Import Data > Vouchers .
2. Enter the name of the .xml file to be imported, in the Import Vouchers screen, as shown below:
Note : By default, the export location is the Tally.ERP 9 installation folder, which is also the default import location. Therefore, it is not required to specify the file path during import. If the path is other than the installation folder, you must specify the exact location path, for example, C:\Export_Files\XML\Master.xml or C:\Export_Files\XML\DayBook.xml
3. Press Enter to import.
Note: You can open the file Tally.imp located in the Tally.ERP 9 installation folder to view the import log.
See Also
Exporting Vouchers
Importing Masters
Cannot Understand Bad Formula
