You can export reports from Tally.ERP 9 in different formats for various reasons like sharing the balance sheet with Shareholders, e-filing returns, and so on.
To export the data
1. Go to Gateway of Tally > Balance Sheet .
2. Click E : Export to open the Export Report .
3. Press Backspace to configure the export options.
o Select Default (All Languages) as the Language .
o Select the Format , as required .
o Enter the Export Location , as required.
o Enter the Output File Name .
o Enable Open Exported Folder to open the folder after export.
4. Select the required options to configure the Balance Sheet before exporting.
5. Press Enter to export.
Exporting Masters
Exporting Vouchers
Export Formats
Importing Data
'Exporting Reports' has been shared with
