https://help.tallysolutions.com/docs/te9rel66/Tax_International/GCC_VAT/accounting_for_tax_liability_under_gcc_vat.htm
Accounting for Tax Liability Under GCC VAT
Related topics
Input Tax Credit
Opening Balance
Your tax liability increases when you need to pay tax to the authority. In certain situations, you need to reverse or decrease the tax liability. For example, you might have to return the advance received from a customer after recording the tax liability. You can use separate journal vouchers to record such tax adjustments.
You can also create a single journal voucher for increasing the tax liability and input tax credit against transactions of imports, purchases from designated zones, or intra-GCC purchases.
● Increase tax liability
● Decrease tax liability
● Increase of tax liability and input tax credit
2. Click J : Stat Adjustment .
o Select Increase of Tax Liability as the Nature of adjustment .
o In the Additional Details field, select the option Interest .
o Press Enter to return to the journal voucher.
3. Debit the expense ledger.
4. Credit the VAT ledger.
5. Press Ctrl+A to accept the voucher.
You can record journal vouchers related to increase of tax liability with the following details:
Nature of Adjustment
Additional Details
Ledgers to be used
Capital Goods
Debit - Expense ledger.
Credit - VAT ledger.
Corrections/Amendments
Exempt and Other Than Business Purposes
Select the Emirate
Imported for Subsequent GCC Transfers
Imports
Intra GCC Purchase
o Select Decrease of Tax Liability as the Nature of adjustment .
o In the Additional Details field, select the option Cancellation of Tax Liability for Advance Receipts .
o Select the location of the party, with reference to whom the tax liability is being cancelled, in the Emirate field.
3. Debit the VAT ledger for decreasing the tax liability. Enter the VAT Rate and Taxable Value in the VAT Details screen.
4. Enter the amount under the Debit column.
5. Credit the current assets ledger grouped under Current Assets .
6. Press Ctrl+A to accept the voucher.
You can record journal vouchers related to decrease of tax liability with the following details:
Additional Details
Ledgers to be used
Select the Emirate
Debit - VAT ledger.
Credit - Ledger grouped under Current Assets .
Capital Goods
Debit - VAT ledger.
Debit - VAT ledger.
Others
Debit - VAT ledger.
Increase tax liability and input tax credit
o Select Increase of Tax Liability & Input Tax Credit as the Nature of adjustment .
o In the Additional Details field, select the option Intra GCC Purchase .
3. Debit the VAT ledger. Enter the Rate and Taxable Value .
4. Credit the VAT ledger. Enter the Rate and Taxable Value .
You can record journal vouchers for increase of tax liability and input tax credit on imports and purchases from designated zones with the following details:
Additional Details
Ledgers to be used
Imports
Debit - VAT ledger.
Purchase from Designated Zone
Debit - VAT ledger.
