https://help.tallysolutions.com/docs/te9rel66/Tax_India/excise-mfg/em-deleting-excise-tax-unit.htm
Deleting an Excise Tax Unit
Excise tax units can be deleted when they are no longer in use or to avoid duplicates. However, you cannot delete an excise tax unit under the following conditions:
If the excise tax unit is created at the company level (while enabling excise).
If the excise tax unit is configured in the stock item master under the option Set/Alter additional info? .
You have to ensure that a tax unit has to be removed from the relevant masters and transactions before deleting it.
To delete a tax unit
1. Go to Gateway of Tally > Accounts Info. > Statutory Info. > Tax Unit > Alter .
2. Select the tax unit.
3. Press Alt+D . The Tax Unit Alteration screen appears as shown below:
4. Press Enter to save.
