https://help.tallysolutions.com/docs/te9rel66/Reports/Display_Registers_Ledgers/Viewing_position_index.htm
Viewing Position Index of Ledgers in Reports
The default value of the position index for all ledgers within a group is always 1000 . You can view the position index of ledgers in the Ledger Alteration screen.
To view the position index of ledgers and its use in display of reports
1. Go to Gateway of Tally > Accounts Info. > Ledgers > Alter .
2. Select the ledger and press Enter to display the Ledger Alteration screen.
3. Click F10: Edit Sort to display the option, Position Index in Reports . The Ledger Alteration screen appears with the option Position Index in Reports .
This value is in relation to other ledgers within the parent group. However you can change the value to sort the display of the ledgers under the parent group in reports.
