https://help.tallysolutions.com/docs/te9rel66/Job_Work/JO_Job_Work_Out_Reports.htm
Job Work Out Reports Menu
You can generate Job Work Out Reports and get accurate stock positions by tracking material movement.
Go to Gateway of Tally > Display > Job Work Out Reports
Job Work Out Reports are:
Order Outstandings
Job Work Registers
Stock
Job Work Analysis
