https://help.tallysolutions.com/docs/te9rel66/Banking/status_for_transactions_under_e-payments_for_dbs_bank.htm
Status of Transactions under e-Payments for DBS Bank
Once you send the transactions to DBS, the transactions are listed under Transactions sent to bank (unreconciled) with any of the following status:
Submitted - When transactions are sent to the bank.
Verifying - Transactions are under verification by the bank.
Authorisation pending - Transactions accepted by the bank and is available for authorization on the bank's portal.
Authorised - Transactions are authorised at the bank's portal by the authorised person.
Processed - Transactions are processed by the bank.
Failed - Transactions failed (due to incorrect sender account no., unregistered TSS ID with bank, and so on).
