https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/VAT_Basics/Enabling_VAT_for_all_States.htm
State Specific Options for Configuring VAT
You can provide state specific tax details while enabling VAT.
In the Company VAT Details screen, click F12: Configure and ensure that the following options are set to Yes.
     Show date from which VAT is applicable?
     Show additional details?
State Name
Enabling VAT
Andhra Pradesh
1.    Enter the 11 digit TIN starting with 36.
2.    Enter the Interstate sales tax number.
3.    Enter the data from which VAT is applicable in the field VAT applicable from.
4.    Set the option Set/alter tax/rate details? to Yes. In the Tax/Rate Details screen, click F12: Configure and set all the options to Yes.
o     Enter the CST Rate Against Form C, Tax rate, and Commodity Code.
o     Select the Schedule and Commodity name (press Ctrl+C).
These details provided at the company level are captured in the relevant fields/rows/columns of the return forms and annexures.
5.    Set the option Define VAT commodity and tax details as masters? to Yes if a VAT Classification which is predefined with tax details has to be applied in the accounts or inventory masters.
6.    Enter the tax filing details in the fields Circle, Division, Authorised person, Status/designation, and Place.
7.    Press Ctrl+A to accept.
Assam
1.    Enter the 11 digit TIN starting with 18.
4.    Select the Periodicity of e-VAT Annexures as Monthly or Quarterly.
5.    Set the option Set/alter tax/rate details? to Yes. In the Tax/Rate Details screen, click F12: Configure and set all the options to Yes.
o     Enter the CST Rate Against Form C, Tax rate, Commodity name and Commodity Code.
o     Select the Schedule and Type of goods.
6.    Set the option Enable VAT calculation on quantity? to Yes to define the tax amount per unit in the stock item master.
7.    Set the option Define VAT commodity and tax details as masters? to Yes if a VAT Classification which is predefined with tax details has to be applied in the accounts or inventory masters.
8.    Enter the tax filing details in the fields S/0, D/o, W/o, Style of business, Name of the goods dealt in, Authorised person, Status/designation, and Place.
9.    Press Ctrl+A to accept.
Bihar
1.    Enter the 11 digit TIN starting with 10.
o     Enter the CST Rate Against Form C, Tax rate, and Schedule Serial No.
o     Select the Schedule, Type of goods, Nature of goods, Commodity name (press Ctrl+C). The Commodity Code appears automatically.
5.    Set the option Define VAT commodity and tax details as masters? to Yes if a VAT Classification which is predefined with tax details, has to be applied in the accounts or inventory masters.
6.    Enter the tax filing details in the fields Status of dealer, Style of business, Authorised person, Status/designation, and Place.
Chandigarh
1.    Enter the 11 digit TIN starting with 04.
o     Enter the CST Rate Against Form C, Commodity name, and Commodity Code.
6.    Enter the tax filing details in the fields Status of dealer, Style of business, Fax Number, District, Ward number, Authorised person, Status/designation, and Place.
Chhattisgarh
1.    Enter the 11 digit TIN starting with 22.
o     Enter the CST Rate Against Form C and Tax rate.
o     Select the Type of goods, Nature of goods, Commodity name (press Ctrl+C). The Commodity Code appears automatically.
6.    Enter the tax filing details in the fields Branch (1), Branch (2), Fax Number, Authorised person, Status/designation, and Place.
Dadra and Nagar Haveli
1.    Enter the 11 digit TIN starting with 26.
o     Enter the Commodity name and Commodity Code.
6.    Set the option Enable VAT calculation on stock item rate? to Yes to define the tax rate for a particular range of amount in the stock item master.
7.    Set the option Define VAT commodity and tax details as masters? to Yes if a VAT Classification which is predefined with tax details, has to be applied in the accounts or inventory masters.
8.    Enter the tax filing details in the fields Authorised person, Status/designation, and Place.
9.    Enter the Exemption/Deferment Details in the fields Entitlement certificate number and Date of completion of exemption.
10.  Press Ctrl+A to accept.
Delhi
1.    Enter the 11 digit TIN starting with 07.
o     Select the Type of goods and Commodity name (press Ctrl+C). The Commodity Code appears automatically.
8.    Enter the tax filing details in the fields Ward number, Authorised person, Status/designation, and Place.
Goa
1.    Enter the 11 digit TIN starting with 30.
4.    Set the option Is Under NPV Scheme? to Yes to account for purchase/sales against restrictive tax invoices.
o     Enter the CST Rate Against Form C, Tax rate, Main Commodity, Commodity name and Commodity Code.
6.    Set the option Define VAT commodity and tax details as masters? to Yes if a VAT Classification which is predefined with tax details has to be applied in the accounts or inventory masters.
7.    Enter the tax filing details in the fields TIN is valid upto, Name of dealer, Status of dealer, Authorised person, Status/designation, and Place.
8.    Press Ctrl+A to accept.
Gujarat
1.    Enter the 11 digit TIN starting with 24.
4.    Select the Periodicity of e-VAT Annexures? as Monthly or Quarterly.
7.    Set the option Consolidate CST and Addl. tax in interstate sales? to:
o     Yes to calculate the tax by consolidating CST and additional tax value on selecting CST ledger in the invoice.
o     No to select CST and additional tax ledgers separately in the invoice.
8.    Enter the tax filing details in the fields Authorised person, Status/designation, Place, District, Fax Number, and Exemption/Deferment Details.
Haryana
1.    Enter the 11 digit TIN starting with 06.
4.    Select the Periodicity of Return? as Monthly or Quarterly.
o     Select the Type of goods, Nature of goods, and Commodity name (press Ctrl+C).
7.    Enter the tax filing details in the fields Style of business, Status of dealer, Economic activity code, Authorised person, Status/designation, Place, and District.
Himachal Pradesh
1.    Enter the 11 digit TIN starting with 02.
5.    Set the option Set/alter tax/rate details to Yes. In the Tax/Rate Details screen, click F12: Configure and set all the options to Yes.
o     Select the Type of goods, Nature of goods and Commodity name (press Ctrl+C).
7.    Enter the tax filing details in the fields Style of business, Income tax circle, Economic activity code, Authorised person, Status/designation, and Place.
Jammu and Kashmir
o     Select the Type of goods.
o     Enter the Commodity name and Commodity code.
7.    Enter the tax filing details in the fields Ward/circle/division, Authorised person, Status/designation, and Place.
Jharkhand
1.    Enter the 11 digit TIN starting with 20.
o     Select the Schedule, Type of goods and Commodity name (press Ctrl+C). The Commodity Code appears automatically.
5.    Set the option Enable VAT calculation on quantity? to Yes to define the tax amount per unit in the stock item master.
7.    Enter the tax filing details in the fields District, Circle/sub- circle, Total amount of deferred tax admissible, Date of eligibility certificate, Authorised person, Status/designation, and Place.
Karnataka
1.    Enter the 11 digit TIN starting with 29.
4.    Select the Periodicity of e-VAT Annexures? to Monthly or Quarterly.
o     Enter the CST Rate Against Form C, Tax rate, Commodity name, Commodity code and Sub Commodity code.
7.    Enter the tax filing details in the fields LVO/VSO code, Authorised person, Status/designation and Place.
Kerala
1.    Enter the 11 digit TIN starting with 32.
o     Enter the CST Rate Against Form C, Tax rate, Cess, and Schedule Serial No.
6.    Enter the tax filing details in the fields Assessing authority address, Branch (1), SSI/MSI/LSI registration number, Authorised person, Status/designation and Place.
Madhya Pradesh
1.    Enter the 11 digit TIN starting with 23.
o     Enter the CST Rate Against Form C, Tax rate, Commodity name, Commodity Code, and Sub Commodity Code.
o     Select the Schedule, Type of goods, and Nature of goods.
8.    Enter the tax filing details in the fields Circle office, Status of business, Nature of Business, Fax Number, Website name, Status of central registration, Authorised person, Status/designation, Place, and Other Information.
Maharashtra
1.    Enter the 11 digit TIN starting with 27.
5.    Select the Applicable VAT Return? as Form 231 or Form 233 to generate the relevant forms.
6.    Set the option Set/alter tax/rate details? to Yes. In the Tax/Rate Details screen, click F12: Configure and set all the options to Yes.
o     Enter the CST Rate Against Form C, Tax rate, Commodity name, and Commodity code.
o     Select the Type of goods  and Nature of goods.
8.    Enter the tax filing details in the fields Status of dealer, Style of business, Fax Number, District, Ward number, Authorised person, Status/designation and Place.
Odisha
1.    Enter the 11 digit TIN starting with 21.
o     Select the Schedule, Type of goods, Nature of goods, and Commodity name (press Ctrl+C).
6.    Enter the tax filing details in the fields Style of business, Fax Number, Authorised person, Status/designation and Place.
Punjab
1.    Enter the 11 digit TIN starting with 03.
o     Enter the CST Rate Against Form C, Tax rate, Surcharge, and Commodity Code.
o     Select the Type of goods, Trade name, and Commodity name (press Ctrl+C).
7.    Enter the tax filing details in the fields Status of dealer, Style of business, Fax Number, District, Code, Ward number, Authorised person, Status/designation, Place and Exemption/Deferment Details.
Puducherry
1.    Enter the 11 digit TIN starting with 34.
o     Enter the CST Rate Against Form C, Tax rate, and Commodity name.
6.    Enter the tax filing details in the fields Assessing authority address, Authorised person, S/o, D/o, W/o, Status/designation and Place.
Rajasthan
1.    Enter the 11 digit TIN starting with 08.
4.    Select the Periodicity of e-VAT Annexures?.
o     Enter the CST Rate Against Form C, Tax rate, Schedule Serial No. and Commodity code.
6.    Set the option Enable VAT calculation on quantity? to Yes to define the tax amount per unit in stock item master.
8.    Enter the tax filing details in the fields Fax Number, Style of business, Authorised person, Status/designation and Place.
Tamil Nadu
1.    Enter the 11 digit TIN starting with 33.
o     Select the Schedule, Type of goods, and Commodity name (press Ctrl+C). The Commodity Code appears automatically.
6.    Enter the tax filing details in the fields Assessment Circle, Division, Area code, Import export code, Authorised person, Status/designation and Place.
Telangana
1.    Enter the 11 digit TIN starting with 37.
6.    Enter the tax filing details in the fields Circle, Division, Authorised person, Status/designation and Place.
Uttarakhand
1.    Enter the 11 digit TIN starting with 05.
o     Enter the CST Rate Against Form C, Tax rate, Cess, Commodity name and Commodity Code.
o     Select the Schedule, Type of goods, and Reporting unit of measure.
7.    Enter the tax filing details in the fields Name of dealer, Status of dealer,  Branch (1), Branch (2), Circle, Sector, Authorised person, Status/designation, and Place.
Uttar Pradesh
1.    Enter the 11 digit TIN starting with 09.
o     Enter the CST Rate Against Form C, Tax rate, and Additional Tax.
o     Select the Schedule and Commodity name (press Ctrl+C). The Commodity Code appears automatically.
7.    Enter the tax filing details in the fields Authorised person, S/o, D/o, W/o,  Status/designation, Place, Assessing authority, Name circle/sector, Branch, and Entitlement certificate number.
8.    Enter the tax invoice details in fields Authorised by, and the corresponding Designation, Issued by and the corresponding Designation.
West Bengal
1.    Enter the 11 digit TIN starting with 19.
o     Enter the CST Rate Against Form C, Tax rate.
o     Select the Schedule, Type of goods, Nature of goods, Major Commodity, Commodity name (press Ctrl+C).
7.    Enter the tax filing details in the fields Name of dealer, Authorised person, Status/designation, Place, and Assessment Circle (Group).
