Employee Vouchers (Payroll)
https://help.tallysolutions.com/docs/te9rel60/Payroll/employee_vouchers.htm
You can view the Employee Vouchers from Payroll Reports or Statutory Reports under Display.
To view the Employee Vouchers
1.    Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary.
     Or
2.    Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary.
3.    Press Enter on the required Pay Head Type.
4.    Press Enter on the required Pay Head.
5.    Press Enter on the required Employee Name.
6.    Click F1: Detailed.
The user can drill down to a corresponding Payroll/Payment Vouchers from the above report.
