Recording Reversal of Input Tax (Goa)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Goa/GA_ITC_Reversal.htm
You can record Reversal of Input Tax by enabling the options in Stat Adjustment Details screen.
To create a journal voucher for reversing tax credit
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select Type of duty/tax as VAT.
o     Select Reversal of Input Tax, as the Nature of adjustment.
o     Select the Others in Additional Details section.
Note: Based on the selection made for Nature of Adjustments, the Additional Details option either appears or disappears.
o     Press Ctrl+A to return to the voucher.
3.    Debit the purchase ledger and tax amount to be reversed.
4.    Credit the VAT ledger. Enter the VAT Details as shown below:
5.    Press Enter to accept and return to journal voucher. The journal voucher appears as shown below:
6.    Press Enter to save.
