Multi Address in Tally.ERP 9
https://help.tallysolutions.com/docs/te9rel60/Advanced_Features/Advanced_Accounting_Features/Multi_Address.htm
The Multi Address feature in Tally.ERP 9 allows you to maintain multiple mailing details for your company and ledgers. Create multiple addresses for your company and use them in invoices and reports. You can print the addresses of your branches or locations in your commercial invoices and reports as required. You can print the Head Office's address along with the branch, godown or registered office address in your Rule 11 invoice.
You can create a single ledger with multiple  addresses and record their statutory details thus avoiding creation of ledgers for each location.
You can print multiple addresses in payment, receipt vouchers.
See Also
Enabling Multi Address
Use Multiple Addresses for Ledger Accounts
Print Multiple Addresses in Reports
