Using Scenarios in Statements and Reports
https://help.tallysolutions.com/docs/te9rel60/Advanced_Features/Advanced_Accounting_Features/Scenarios_in_Statements_and_Reports.htm
You can use scenarios in statements (not registers) to  compare the actuals with the provisional details by using the N: New Column button.
To use scenarios
1.    From Gateway of Tally, click Balance Sheet.
2.    Click N: New Column.
3.    Select the scenario required.
The Balance Sheet with the scenario appears as shown below:
Note: The Provision for Depreciation figures in both the columns. The actual column shows 18250 while the Provisional column shows 33250. This is on account of the reversing journal entry in the Scenario.
