Issue Variance Analysis Report (Job Work Out)
https://help.tallysolutions.com/docs/te9rel60/Job_Work/JO_Job_Work_Analysis_Issue_Variance.htm
Issue Variance report displays the details of variance in the raw material/components issued against the ordered Quantity of the Job Work Out Order. Report also displays the variance Quantity and the Percentage of variance.
To view the stock Issue Variance report
Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Analysis > Issue Variance
