Recording a POS Invoice
https://help.tallysolutions.com/docs/te9rel60/Advanced_Features/Advanced_Inventory_Features/Creating_a_POS_Invoice.htm
A POS  transaction is recorded using the PoS Invoice Voucher Type created.
To record a POS transaction
1.    Go to Gateway of Tally > Accounting Vouchers > F8: Sales to view the Change Voucher Type screen.
2.    Select POS Invoice as the Voucher type.
3.    Select the Godown, as required.
4.    Select the Party's A/c Name, as required.
5.    Select the Sales Ledger, as required.
6.    Select the Name of Item or create a new stock item.
7.    Set the Rate of the item, as required.
8.    Select VAT/Tax ledger from the list of Ledger Accounts.
The Accounting Voucher screen appears as shown below:
9.    Press Enter to save.
Note: POS invoices can be recorded with different actual and billed quantities by enabling the option  Use separate actual and billed quantities in F11 (Features) > F2(Inventory).
