Decrease in Input Tax (Rajasthan)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Rajasthan/RJ_Decr_Input_Tax.htm
You can create a journal voucher for CST adjustment with Decrease of Input Tax as  the nature of adjustment.
To create journal voucher for CST adjustment
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Decrease of Input Tax in the Nature of adjustment field.
o     Press Enter to save, and return to voucher screen.
3.    Debit the CST ledger created under the group Duties & Taxes.
o     Enter the Rate, Assessable Value and Schedule Serial No., and select the Schedule Name in the VAT Details screen.
5.    Credit the input VAT ledger.
6.    Press Enter to save.
