https://help.tallysolutions.com/docs/te9rel60/Job_Work/Job_Work_Registers.htm
Job Work Registers (Job Work Out)
You can display all the material in vouchers recorded to account the transfer and receipt of stock.
To view the Job Work Registers
●     Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Registers.
The Job Work Registers are:
●     Job Work Out Orders Book
●     Material Out Register
●     Material In Register
●     Material Movement Register
Job Work Out Orders Book displays all the Job Work Out Order Vouchers recorded in the Books.
To view the Job Work Out Orders Book
●     Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Register > Job Work Out Orders Book
To view the monthly summary
1.    Click N: Auto Column.
2.    Set the Periodicity as Monthly.
3.    Set the option Show Total? to Yes.
The Job Work Out Orders monthly summary will be displayed for the selected period.
Material Out Register Report (Job Work Out)
Material Out Register displays all the material out vouchers recorded to account the transfer of Material to the Job worker Location.
To view the Material Out Registers
●     Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Register > Material Out Registers
Material In Register Report (Job Work Out)
Material In Register displays all the material in vouchers recorded to account the receipt of finished goods from the Job worker Location.
To view the Material In Registers
●     Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Register > Material In Registers
Material Movement Register Report (Job Work Out)
Material Movement Register displays the details of Movement of Material (Raw Materials and Finished Goods) of Job Orders.
To view Material Movement Register
●     Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Register > Material Movement Register
