Configurations for Master (Excise for Importer)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/Excise_Importer/Configurations_for_Masters.htm
Configurations for Masters (Excise for Importers)
You can configure the masters used for recording transactions related to excise for importers.
More Configurations
Configurations while creating excise godowns include:
Allowing Aliases along with Names
In certain businesses, a party can have an official names as well as an alias name. This option enables you to maintain aliases for names.
To allow aliases along with names
1.    Go to Gateway of Tally > Inventory Info. > Godowns/Excise Units > Create > F12.
2.    Enable the option Allow aliases along with names.
Allowing Language Aliases for Names
Some businesses require maintaining names in languages other than the default language English. In such cases this option is enabled.
To allow language aliases for names
1.    Go to Gateway of Tally >Inventory Info.> Godowns/Excise Units > Create > F12.
2.    Enable the option Allow language aliases for names.
Using Addresses for Godowns
Addresses defined here is captured in transactions involving movement of goods from one godown to another another or a when selling goods from a godown.
To use addresses for godowns
2.    Enable the option Use addresses for godowns.
