Recording Decrease in Output Tax - TDS Adjustment (Assam)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Assam/AS_Decr_Output_tax.htm
Decrease in output tax can be adjusted by creating a journal for TDS adjustment.
To create a journal voucher for TDS adjustment
2.    Click J: Stat Adjustment.  In the Stat Adjustment screen,
o     Select Type of duty/tax as VAT.
o     Select Decrease of Output Tax, as the Nature of adjustment.
o     Select the TDS Adjustment in Additional Details section.
Note: Based on the selection made for Nature of Adjustments, the Additional Details option will appear or disappear.
o     Press Ctrl+A to return to the voucher.
3.    Debit the VAT ledger created under the group Duties & Taxes.
o     Enter the Rate and Assessable Value in the VAT Details screen.
5.    Credit the ledger created under the group Current Assets.
6.    Press Enter to save.
