Reversal of Input Tax (Rajasthan)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Rajasthan/RJ_Reversal_Input_Tax.htm
You can record a journal voucher to capture reversal of input tax by selecting Reversal of Input Tax as the nature of adjustment.
To create a journal voucher of reversal of input tax
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Reversal of Input Tax as Nature in the Nature of adjustment field.
o     Select the option Stock Transfer in the Additional Details field.
o     Press Enter to save and return to voucher screen.
3.    Debit the purchase ledger.
o     Select the Name of Item and enter  the Amount in the Inventory Allocations screen.
5.    Credit the VAT ledger.
o     Enter the VAT Details as shown below:
6.    Press Enter to save.
