Annexure - IV (Job Work Out Reports)
https://help.tallysolutions.com/docs/te9rel60/Job_Work/Annexure_IV.htm
As per Rule if the principal manufacture is sending the excisable goods for Job work the material Movement details has to be maintained in Annexure - IV. In Tally.ERP 9 Annexure - IV can be generated when the Excise for Manufacturer feature is enable in F11: Features.
To view Annexure - IV
1.    Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Registers > Annexure - IV.
2.    Select the Excise Unit for which the Annexure - IV  has to be generated, in the Select Item screen.
The Annexure - IV is displayed as shown:
