Decrease in Output Tax (Rajasthan)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Rajasthan/RJ_Decr_Output_Tax.htm
You can record a journal voucher to capture the decrease in output tax by selecting Decrease of Output Tax as the nature of adjustment.
To create journal voucher for decrease in output tax
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Decrease of Output Tax in the Nature of adjustment field.
o     Select the option Not Applicable in Additional Details field.
o     Press Enter to save and return to voucher screen.
3.    Debit the VAT ledger created under the group Duties & Taxes.
o     Enter the Rate, Assessable Value and Schedule Serial No., and select the Schedule Name in the VAT Details screen.
5.    Credit the ledger created under the group Current Liabilities.
6.    Press Enter to save.
