You have to enable Is Inclusive of duties and taxes? at the stock item master to define the price of the stock item including tax.
To record inclusive of tax sales transaction
1. Go to Gateway of Tally > Accounting Vouchers > F8: Sales.
2. Select the party ledger in Party's A/c Name field.
3. Select the sales ledger with taxable nature of transaction.
4. Select the stock item for which the option Is inclusive of duties and taxes? is enabled.
To create stock item with inclusive of tax configuration
2. Click F12: Configure.
o Set Allow inclusive of tax for stock items? to Yes.
o Press Ctrl+A to accept.
3. Enter the name of the stock item in the Name field.
4. Select the required stock group in the Under field.
5. Select unit of measurement in the Units field.
6. Select the option Applicable in the VAT Applicable field.
7. Enable the option Set/alter VAT details?.
o Enter Tax rate. The option Tax type is set to Taxable if tax rate is above 0 in VAT Details screen.
8. Set Is Inclusive of duties and taxes? to Yes.
9. Press Enter to save.
5. Enter the Quantity. The Inclusive of Tax screen appears as shown below:
o Enter the Rate (Inclusive of Tax).
o Press Enter to save and to return to sales invoice.
6. Select the common VAT ledger. Based on the VAT rate, amount is automatically displayed.
The ledger must be grouped under Duties & Taxes in which the options:
● Type of duty/tax set to VAT (CST in case of interstate sales).
● Percentage of Calculation (eg 5)? set to 0.
7. Enter Narration, if required.
8. Press Enter to save.
'Recording Sales Inclusive of Tax (Odisha)' has been shared with
