Creating Stock Group (Excise for Dealer)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/Excise_Dealer/Group_Dlr.htm
You can create a stock group enabled for dealer excise by entering the relevant details.
To create a stock group
1.    Go to Gateway of Tally > Inventory Info. > Stock Groups > Create.
2.    Enter the Name of the stock group.
3.    Set the option Set/Alter VAT Details to Yes/ No as per requirement. Click here to view the detailed procedure of defining VAT details in stock group.
4.    Set the option Set/Alter Excise Details to Yes.
5.    Provide relevant details in Excise Details screen.
6.    Accept the Stock Group Creation screen.
