Recording Purchases from Lump Sum Dealers (Haryana)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Haryana/Purchase_from_Lump_sum_Dealers.htm
Purchases made from lump sum dealers can be recording by considering a purchase ledger where VAT is applicable and the nature of transaction is set to Purchase From Composition Dealer.
To record purchases from lump sum dealers
2.    Click F12: Configure button.
3.    Set the option Allow modification of Tax Details for VAT? to Yes.
4.    Press Ctrl+A to save and return to invoice.
5.    Enter the Supplier Invoice No. and Date if any.
6.    Select the supplier ledger in Party’s A/c Name field whose Type of Ledger is set as Composition in the ledger level.
7.    Select a purchase ledger in which the option:
o     Is VAT/CST Applicable? is set to Applicable.
o     Set/Alter VAT Details? is enabled.
o     Nature of Transaction is set to Purchase From Composition Dealer.
8.    Select the required stock items. Enter Quantity and Rate for each stock item.
9.    Press Enter to save.
