Recording Taxable Purchases (Puducherry)
https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Puducherry/PY_Tax_Pur.htm
You can create vouchers for purchase of items attracting tax with the VAT rates specified either at the stock item level or at the stock group level.
To record transaction of local purchase for items attracting multiple VAT rates
2.    Enter Supplier Invoice No. and Date.
3.    Select the supplier ledger in Party's A/c Name field.
4.    Select the common purchase ledger in which the option Is VAT/CST Applicable? is set to Applicable, and Set/Alter VAT Details? is disabled.
5.    Select the required stock items whose VAT rates are specified either at the stock group or stock item level. Enter Quantity and Rate for each stock item.
6.    Select the common VAT ledger.
7.    Click A: Tax Analysis to display the Tax Analysis screen.
o     Click F1: Detailed to view the names of stock items. The Tax Analysis screen appears as shown below:
o     Press Esc to return to purchase invoice.
8.    Press Enter to save.
