Configurations in Masters for TDS
https://help.tallysolutions.com/docs/te9rel60/Tax_India/TDS/Configurations_in_Masters.htm
You can enable advance configurations for TDS in party masters. This will allow you to configure surcharge exemption limits, and income exemption limits. You can also set a zero or lower rate of TDS for party masters.
Ignore surcharge exemption limit
Ignore income tax exemption limit
Set zero/lower rate for TDS
