Creating TDS Ledger
https://help.tallysolutions.com/docs/te9rel60/Tax_India/TDS/TDS_Ledger.htm
Creating TDS Ledger
A TDS ledger is used for recording duties in TDS-related transactions.
To create a TDS tax ledger
1.    Go to Gateway of Tally > Accounts Info. > Ledgers > Create.
2.    Enter the Name.
3.    Select Duties and Taxes as the group name in the Under field.
4.    Select TDS as the Type of Duty/Tax.
5.    Select a Nature of Payment  from the List of Nature of Payments.
6.    Press Enter.
7.    Press Ctrl+A to save the details.
