Identifying Related Parties (International)
https://help.tallysolutions.com/docs/te9rel60/Auditor_Edition/International_Audit/Identifying_related_Parties.htm
Those Ledgers which are marked by the user as Related Party will only appear in the Related Party Transactions report.
To identify/mark a Ledger as Related Party
1.    Go to Gateway of Tally > Analysis & Verification > Verify > Related Party Transactions.
o     Click on Ctrl+F9: Master Config or press Ctrl+F9.
o     Select Related Party and press Enter.
o     Select the required Ledgers using Spacebar in the Related Party Configuration screen.
o     Click on F5: Update or press F5 to view Related Party Details screen to mark the selected Ledger as Related Parties.
o     In Related Party Details screen.
o     In Is Related Party field select Yes.
o     In Relation Type field specify the relation type.
o     Press Enter to save the Related Party Configurations.
Note: Follow the same steps to unmark a Party which is wrongly identified as Related Party.
Press Escape to view the Related Party Transactions report.
Ctrl+W: Wkg Paper
To view the Working Paper during analysis, click on Ctrl+W: Wkg Paper or press Ctrl+W . The details displayed in Working Paper will be relevant to report from where it is triggered. This report displays the details of Configuration of Periodic Ledgers.
