                                    You can create Bonus Pay Heads to account for the bonus that has been paid to employees.
To create a Bonus Pay Head
2. Enter pay head name in the Name field.
3. Select Bonus as the Pay head type from the list of Pay head type.
4. Select the Income type for the pay head.
o By default, Affect Net Salary is set to Yes. Type No, if you do not want this component to be included in the pay slip.
o By default, the pay head component name entered in the Name field appears in the pay slip. Enter the Name to appear in Payslip if you want to change the default pay head component name.
o By default, Use for calculation of gratuity is set to No.
6. In the Income Tax Details screen:
o Select Other Earnings/Allowances (Fully Taxable) as the Income Tax Component.
o Select On Actual Value as Tax Calculation Basis, if the amounts applicable to this pay head vary each month, to rationalise and spread tax across the remaining period. If the amounts are fixed, select On Projected Value.
o Set Deduct TDS across Period(s) to Yes to deduct tax across the remaining period. If this is set to No, the entire tax is deducted in the same month.
7. Set Exclude for ESI Eligibility to Yes, if you want to this pay head to be considered for ESI Calculation, but not for ESI Eligibility.
8. Set As User Defined Value, from the List of Calculation, as the Calculation type.
9. Press Enter to accept.
'Creating a Bonus Pay Head (Payroll)' has been shared with
