https://help.tallysolutions.com/docs/te9rel60/Tax_India/VAT/Maharashtra/MH_return_auto_populated_from_TE9.htm
Will all fields in the return be auto-populated based on the information exported from Tally.ERP 9?
No, data to the extent of pre-defined transaction codes is auto-populated in the forms. The remaining values have to be manually entered.
