https://help.tallysolutions.com/docs/te9rel60/Tax_India/Excise_Mfg/em_duty_ledgers_not_calculating_excise_on_mrp.htm
Why are additional duty ledgers enabled for excise not considered for excise duty calculation when the valuation type is selected as MRP based? (Excise for Manufacturer)
As per the statutory rules, when an excise invoice is recorded for MRP based items, the excise duty is assessed only from the MRP of items. Hence, the additional duty ledgers are not considered for excise duty calculation.
