https://help.tallysolutions.com/docs/te9rel60/Job_Work/JO_Job_Work_Out_Reports.htm
Job Work Out Reports Menu
You can generate Job Work Out Reports and get accurate stock positions by tracking material movement.
To view the Job Work Out Reports
Go to Gateway of Tally > Display > Job Work Out Reports
Job Work Out Reports are:
     Order Outstandings
     Job Work Registers
     Stock
     Job Work Analysis
