https://help.tallysolutions.com/docs/te9rel60/Error_warning_message/trans_Voucher_total_do_not_match.htm
Voucher totals do not match! Dr. XXXX Cr XXX Diff: X CR (account invoice mode)
Cause
The above error message is displayed when the total debit in the voucher does not match the total credit.
Solution
This error can be resolved by matching the debit and credit totals of the voucher.
