https://help.tallysolutions.com/docs/te9rel60/Banking/cursor_skips_when_modifying_bank_ldgr.htm
When Modifying a Bank Ledger, Why Does the Cursor Skip from the Bank Details Field?
While altering a bank ledger, the cursor skips the Bank Details section as the required information is available.
However, if you want to make changes to the bank details, press Backspace to move to the respective bank details fields and make the required change.
