To record transaction by overriding Assessable Value and Tax, you have to configure the sales invoice for overriding tax details in F12: Configure .
To record transaction by overriding tax details
2. Click F12: Configure to configure the sales invoice for overriding tax details.
In the configuration screen,
1. Set Use common ledger A/c for item allocation? to No .
2. Set Allow modification of Tax Details for VAT? to Yes .
3. Press Ctrl+A to accept.
3. Select the customer ledger in Party's A/c Name option.
4. Select the required stock items whose VAT rates are specified either at the stock group level or at the stock item level. Enter Quantity and Rate for each stock item.
5. Select a common sales ledger in which the option Is VAT Applicable? is set to Applicable , and Set/Alter VAT Details? is disabled in the Accounting Details screen.
o Click F12: Configure in VAT Classification Details screen to configure override of tax rate.
To enter tax rate in the Configuration screen
1. Set Allow override Assessable Value? to Yes .
2. Set Override tax rate? to Yes .
o Select the Classification/Nature in VAT Details screen.
o Enter the required Tax rate .
o Enter the Assessable Value . The VAT Details screen appears as shown below:
o Press Enter to return to invoice.
6. Select the common VAT ledger.
The ledger must be grouped under Duties & Taxes in which the options :
● Type of duty/tax is set to VAT .
● Percentage of Calculation (eg 5)? is set to 0% .
7. Press O to override the default tax details and save invoice with the changed tax rate and assessable value.
'Overriding Assessable Value and Tax in Invoice (Kenya)' has been shared with
