To capture increase in input tax, you can create a journal voucher with Increasing Input Tax as the nature of adjustment.
To create journal voucher for tax credit on opening stock
2. Click J : Stat Adjustment . In the Stat Adjustment Details screen,
o Select the option Increasing Input Tax in the Nature of adjustment field.
o Press Enter to save and return to voucher screen.
3. Debit the input VAT ledger.
o Enter the Rate , Assessable Value and Schedule Serial No. , and select the Schedule Name in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the purchase ledger.
o Select the Name of Item and enter the Amount in the Inventory Allocations screen.
6. Press Enter to save.
'Increase in Input Tax (Rajasthan)' has been shared with
