This report allows you to track pending goods to be delivered to merchant exporter using CT-3 numbers recorded in sales orders. CT-3 (certificate 3) is the certificate on the basis of which merchant exporter procures excisable goods. The certificate number and date is recorded in sales order in Tally.ERP 9 to enable tracking.
CT-3 Outstandings report provides details of order, delivered and pending quantity for a CT-3 number.
To view CT-3 Outstandings report
1. Go to Gateway of Tally > Display > Statutory Reports > Excise Reports > Manufacturer > Export Register > CT–3 Outstandings .
2. Select the name of merchant exporter in the field Name of Party Ledger .
3. Select CT-3 number or Any in the field CT-3 Number . Select Any to view all outstanding CT-3 orders for the selected party.
The CT-3 Outstandings report for all CT-3 numbers for a particular party appears as shown below:
The information displayed in the report is described below table:
      Field  |
      Description  |
      Excise Unit Name  |
      Displays the excise unit name for which the goods are delivered against the sales order.  |
      Party Ledger  |
      Displays the name of merchant exporter on whom the sales order is placed.  |
      Date  |
      Displays the date on which the sales order is recorded.  |
      Order Number  |
      Displays the voucher number of the sales order.  |
      Description of Goods  |
      Displays the name of the goods selected in the sales order.  |
      CT-3 No. and Dt.  |
      Displays the CT-3 No. and date recorded in the Certificate No. and Date field in Order Details section Party Details screen in the sales order voucher.  |
      Ordered Quantity  |
      Displays the quantity order for each stock item in the sales order.  |
      Supplied Quantity  |
      Displays the supplied quantity for each stock item, the supply can be through a sales invoice or delivery note.  |
      Balance Quantity  |
      Displays the quantity pending to be delivery for each stock item.  |
      ARE-3 No. and Date  |
      Displays the ARE-3 serial number and date recorded in the ARE Details screen of the sales invoice.  |
'CT-3 Outstandings Report (Excise for Manufacturer)' has been shared with
