                                    You can view the Summary employee-wise breakup of the Computation for the required Pay Head from the Payroll Reports or Statutory Reports .
To view employee-wise breakup
1. Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary .
Or
2. Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary .
3. Press Enter on the required Pay Head Type.
4. Press Enter on the required Pay Head.
The user can drill down to a corresponding Employee Voucher from the above report.
Click F2: Period to change the selected period.
Click F12: Configure show/hide the Employee Number .
'Employee Breakup of Pay Head (Payroll)' has been shared with
