Displaying a Stock Group
https://help.tallysolutions.com/docs/te9rel63/Creating_Masters/Inventory_Info/Displaying_a_Stock_Group.htm
You can display the existing Stock Group in Single mode and multiple mode, since it is only display Tally.ERP 9 does not allow you to alter any information in display mode.
To display Single Stock Group
1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Display (under Single Stock Group)
2. Select the Stock Group whose particulars you want to display from the List of Groups . The Stock Group Display screen is displayed as shown.
Buttons specific to stock group Display mode
Buttons
Short cut Keys
Description & Use
C: Category
CTRL+C
Allows you to Display a Stock Category.
I: Items
CTRL+I
Allows you to Display a Stock Item.
U: Units
CTRL+U
Allows you to Display a Unit of Measure.
O: Godown
CTRL+O
Allows you to Display a Godown.
V: Vch Types
CTRL+V
Allows you to Display a Voucher Types
Note: Category and Godown buttons are visible only if you opted for the same in F11: Features .
To display Multiple Stock Groups
1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Display (under Multiple Stock Groups)
2. Select the Stock Group from the List of Groups .
If you select All Items from the List of Groups , all the Groups and sub Groups are displayed.
If you select Grade One from List of Groups , all the sub Groups related to Grade One will be displayed.
Buttons specific to Multi stock group Display mode:
Buttons
Shortcut Keys
Description & Use
F4: Parent
CTRL+F4
Allows you to select parent [Stock Group] from List of Group . Selected Stock Group will get displayed.
C:Category
CTRL+C
Allows you to select Category from List of Categories . Selected Stock Category will get displayed.
I: Items
CTRL+I
Allows you to select Stock Group from List of Groups . Selected Stock Group will display related stock items.
O: Godown
CTRL+O
Allows you to select Godowns from List of Godowns . Select Godowns will get displayed.
Note: Category and Godown buttons are visible only if you have opted for the same in F11: Features.
