To record a transaction with decreased input tax value, you can create a journal voucher with the necessary Stat Adjustments, debit your CST ledger, and credit the input VAT ledger.
To create journal voucher for decreasing input tax
2. Click J : Stat Adjustment . In the Stat Adjustment Details screen,
o Select the option Decrease of Input Tax in the Nature of adjustment field.
o Select the option Against CST in the Additional Details field.
o Press Enter to save and return to voucher screen.
3. Debit the CST ledger created under the group Duties & Taxes .
o Enter the Rate and Assessable Value in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the input VAT ledger created under the group Current Assets .
6. Press Enter to save.
'Recording Decrease in Input Tax (Delhi)' has been shared with
