CST payable can be adjusted against the available input tax credit. You can record a journal voucher with the required nature of adjustment to make this adjustment in the books of accounts.
To adjust CST payable against available input credit
2. Click J : Stat Adjustment . In the Stat Adjustment Details screen,
o Select Type of duty/tax as VAT .
o Select Decrease of Input Tax as Nature of adjustment , as shown in the image above. The option Against CST is selected by default.
3. Debit the CST ledger created under the group Duties & Taxes .
o Enter the Rate and Assessable Value in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the VAT ledger created under the group Duties & Taxes .
6. Enter Narration , if any.
7. Press Enter to save.
'Decrease of Input Tax (Tamil Nadu)' has been shared with
