https://help.tallysolutions.com/docs/te9rel63/Tax_International/GCC_VAT/gcc_vat_opening_balance.htm
GCC VAT Opening Balance
You can record the opening balance for your VAT account by debiting the VAT ledger and crediting the current assets ledger.
Record opening balance of VAT
2. Click J : Stat Adjustment .
o Select Opening Balance as the Nature of adjustment .
o Press Enter to return to journal voucher.
3. Debit the VAT ledger.
4. Credit the current asset ledger.
5. Press Ctrl+A to accept the voucher.
