You can export masters created in a company, in different formats. You can also choose the type of masters to export. Masters exported in XML format can be imported into Tally.ERP 9 using the Import Masters option.
To export masters
1. Go to Gateway of Tally > Display > List of Accounts .
2. Click E : Export to open the Export Report .
3. Press Backspace to configure the export options.
4. Select the Language .
5. Select the Format .
6. Enter the Export Location .
7. Enter the Output File Name .
8. Select the Type of Masters to be exported.
9. Set the option Include dependent masters? to Yes .
10. Enable Export Closing Balances as Opening , if required. The Export Report screen appears as shown below:
11. Press Enter to export.
The exported file is saved in the location specified.
'Exporting Masters' has been shared with
